Cameras were showing low battery. I bought a new 16 pack of batteries and replaced them. All four cameras drained within 48 hours. Assumed it was a bad batch of batteries. Went out bought a new set of Energizer batteries, replaced them and toggled all the cameras Off. Purpose of that was to toggle them back On when I had time to monitor them to see what was causing them to drain. Toggled them On 2 days later, all drained! Prior to those two sets of batteries cameras worked fine. Software was up to date. Any thoughts or comments appreciated.
Is your base being turned off at any point? If so, don't - the cameras waste the batteries trying to connect to the nonexistent base.
I will have to trouble shoot that again. When I changed the first set, all cameras connected fine and were on a scheduled timer. The second time I replaced the batteries all cameras connected, recorded and showed 100% charge. Everything looked normal as previous times except that they drained too fast these last few times. I may have to buy another pack and try one camera at a time. I would like to rule out any other possibility before I keep dumping money into those batteries. Thanks for the reply.
Might be worth getting some of the tenergy rechargeable batteries.
Since they used to work fine, I would look for some wireless device near your base that could be causing interference. Could be a new device or one that got moved. You could also try moving the base away from the router. As a last resort, remove everything from Settings, My Devices and start fresh. To avoid buying more batteries, just add one camera as a test.
Yes. I actually had them before but the movers wouldn’t pack them up so I’m waiting to get final settled somewhere before I buy them again. I found a mixture of 4 left over batteries from previous purchases. I will try those on one cam only.
