Base station
My base station Model: VMB3000 was on, then turned off. It does not turn on.
I have tried unplugging it and resetting it, but nothing works. Am I missing something or did it just die?
Thank you.
Are there any leds lit on the base ??
If not and it was running, it can only be the power or base itself. ( only can be checked if you have another power adapter for the base ).
I would unplug from all and then temp test in another outlet.... but could be the base.
If less than a year old , contatct Arlo support for possible warranty.
I have unplugged and plugged the base station a few times. Each time I press the on button, two LED lights go on for one second then turn off. That's it. Nothing else happens.
Hi @Songbird
