- 2
My arlo system was working perfectly up till this morning, when all of a sudden the netgear receiver decided it wasn't going to connect to the internet. I have tried absolutely everything that is in the forums. And its still doing it. I even went out and bought a new base station just now, and it does exactly the same thing, will not connect to the internet.
This is an absolute joke. Its not my end, so what is happening on netgears end? My internet connection is working well, all my other computers and tvs in the house connect to the internet just fine, i have tried different cables, i have tried resetting, i even deactivated the base station to try that, but of course, now i can't reactivate it cause it won't see the internet.
Fix this problem, its a joke
Ports 80 and 443 need to be open for Arlo to work. This could be blocked by your router or software firewall/antivirus on the computer. Can you connect with a mobile device? Can you connect to the web UI at all? If so, does it give you a base station isn't connected error (or similar)? Try logging out and back into Arlo.
My internet connection is working well, all my other computers and tvs in the house connect to the internet just fine, i have tried different cables, i have tried resetting, i even deactivated the base station to try that, but of course, not working. Please help.
I'm experiencing the exact same thing. Been working fine for last 3 months, this morning second light, the internet light is orage. rebooted base station, no change. rebooted modem/router no change. After about 10 min internet light went green for about 30 sec, then orange again.
Am wondering if there was a firmware update overnight for the base station because in another thread some apparently had a higher firmware than I had and that was supposed to be the current one.
Definitely something going on. All 3 lights on base station green but trying to log in to site gets message "We're sorry Arlo is currently unavailable. Please try again later"
Suggest sitting back and waiting. Problems apparently aren't at local level and higher ups working on it
Ok. All back to normal here, then orange internet light then green, now amber again. And yes, there was a base station firmware update.
2.3.2.801_16324
Is it the latest version?
That isn't the base firmware version. Use Settings, My Devices, your base, Device Info. Compare using the Release Notes forum here.
http://downdetector.com/status/aws-amazon-web-services/map/ shows AWS having issues.
Right church, wrong pew. You posted the hardware version. AT the bottom of that secttion is a listing of the firmware. Mine is 1.8.9.0_11528.
Do I need to upgrade? The base station still cannot connect to internet. I have tried to reboot everything.
Fymirene wrote:
Mine is 2.3.2.801_16324
I think you're still telling me the APP version. No base firmware is above v1.8x.
My system seems to have settled down now - the server issue seems to be resolved although it may be just at the times I happen to check.
Log out and back in. Are you using the app or browser? Try the other to see if it's a display issue with the one you're using.
Use a browser, too. Also, try power cycling the base, just in case.
- 2
