I'm trying to add a 4th camera to my system.
Any suggestions?
I didn't have to use particular force but it sounds like yours has a slight (?) issue. As long as you're good with it, seems like you found the fix...
Hello @bbates7995,
I've sent you a private message as a follow up regarding the issue you were having.
Looking forward to hearing from you.
KristynM
Arlo Support Team
attempting to add another camer
base station will not flash green on the sync light but the usb starts flashing yellow and it will not go into sync mode
tried holding down as indicated above to no availe
Are you pressing and releasing the sync button fairly quickly or holding it down? If the latter, don't. You only need a brief button press.
Trouble ticket.
I tried syncing my 5th camera last night and it worked! I did nothing different as before. I held the sync button on the base station for 1-2 seconds, the sync light on the base station began to flash and I synced my camera successfully. Weird that it didn't work the 20 other times I tried previously...
I just purchased mine and the base station will not sync. I do not see any replies. What to do?
What LEDs are lit and what colors? Need details.
The most common mistake is users hold the sync button on the base to long...it's a quick push, not a hold.
(hold the sync button to long and the base goes into a usb mode )
MMcCoy wrote:
I am trying to sync. a 4th camera and I am having the same problem. The light on the base will not flash green no matter how long I hold the sync. button. Any help would be appreciated. 3 cameras do not serve my need, I need 4.
You did read the post before yours? It says if you hold the Sync button too long, it'll switch into a different mode.
To sync, you need to press the button on the base station briefly. Don't hold it down for long.
Since your base station could be in any state at this point, I'd suggest resetting it and starting over with registering it and all of your cameras.
MMcCoy wrote:
If I don't hold the button down for approx. 15 sec. It doesn't flash at all. I synced 3 other cameras right before the 4th and all worked fine. I'm not doing anything different...
So, after pressing the sync button on the base station for 15 seconds what LED blinks (if any at all) and in what color?
Are you saying that if you just briefly press on the base station's sync button, the third LED from the left on the base station will not start blinking? If that is the case, I'm wondering if your base station still has old firmware. Can you post your base station's firmware version number? Mine is showing as 1.7.3_5005 and I believe that is the most current version, since when I tap on the number in the device settings I get the message "No updates available".
I believe originally when the product was released a little over a year ago, the sync button on the base station did have to be pressed longer (though certainly not 15 seconds) to initiate the synchronization process. Meanwhile that has changed to a brief button press.
