Using Android app 2.1.3_14043 (08/15/16) on a Samsung Galaxy S5 (up-to-date).
Also tried via Arlo Netgear website, but same result.
Description:
I cannot see the cameras or log into the base station, only get "Your device is not connected. Make sure it's connected to your router and has a working Internet connection." This is at my house and I have no Internet problems here. Before this I have used the Arlo Netgear for months without problems, just one day the base station was not online and not possible to see the videofeed.
However I can see all the alarms and videos from alams, both locally and when I'm far away.
The situation has persisted a couple of weeks now. I cannot change mode either.
I have the same setup at my holiday house, no problems before or now.
I have tried to restart the base station, without effect.
I hope you have some fresh ideas or solution for me - looking forward to hearing from you!
EDIT: ligts are green (power), orange (internet), green (cameras).
Best regards,
Egil
Norway
"EDIT: ligts are green (power), orange (internet), green (cameras)."
Something has changed with your service or router...All three LEDs must be green for it to function properly.
I would take all offline and then re-boot your modem. then router, then Arlo in that order. If the internet LED stays amber, then maybe check the ethernet cable too.
