  • 2 Replies
  • 3110 Views
egilu
Using Android app 2.1.3_14043 (08/15/16) on a Samsung Galaxy S5 (up-to-date).
Also tried via Arlo Netgear website, but same result.
Description:
I cannot see the cameras or log into the base station, only get "Your device is not connected. Make sure it's connected to your router and has a working Internet connection." This is at my house and I have no Internet problems here. Before this I have used the Arlo Netgear for months without problems, just one day the base station was not online and not possible to see the videofeed.
However I can see all the alarms  and videos from alams, both locally and when I'm far away.
The situation has persisted a couple of weeks now. I cannot change mode either.
I have the same setup at my holiday house, no problems before or now.
I have tried to restart the base station, without effect.
I hope you have some fresh ideas or solution for me - looking forward to hearing from you!
EDIT: ligts are green (power), orange (internet), green (cameras).
Best regards,
Egil
Norway
"EDIT: ligts are green (power), orange (internet), green (cameras)."
Something has changed with your service or router...All three LEDs must be green for it to function properly.
I would take all offline and then re-boot your modem. then router, then Arlo in that order. If the internet LED stays amber, then maybe check the ethernet cable too.
egilu
Thank you TomMac, you saved my weekend! 🙂
