Today I went to check my cameras and saw the overly common “ not connected to internet” message. Normally after 4 years of this garbage system I would not be concerned. Usually a simple power down and up with solve the issue. This time is different. After several reboot attempts all I get is an amber power light. It makes no attempt to cycle through. Any thought ? Is it finally dead? Is there a different restart procedure?
Thanks.
You try removing the base from the account, and then reset it using this procedure: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
Then add the base back.
does not work. terrible product
Hi atistailor,
Could you clarify what problems you're having with your Arlo product?
Hey Showguy,
If resetting your Base Station did not solve the issue, I would suggest to contact the Support Team so they can look into this further. You can find several options for contacting support in the provided link.
