Base station has 3 green lights but cameras and doorbell will not work. When trying to view cameras keep getting the message no internet connection. Tried rebooting many times with no luck even though I get 3 green lights on the base. Any suggestions?
Tart,
Are the cameras showing offline in the Arlo mobile app? Do you experience the same behavior if you try view using a different device?
Try rebooting your router and base, in that order.
