I cannot get past the setup of this base station (VMB3500, part of the VMS3330 security system). The power and internet lights are both green (camera sync light is amber). I am able to begin the setup process,, and the base station is recognized, but the process fails after I try to assign a name to the device. When attempting the base station setup via my PC, I get the error message "Aria Account creation failed." When I attempt it through the app, I get "We're sorry, Arlo is currently unavailable. Please try again later."
Neither of these error messages are remotely descriptive. This is a new setup and I've factory reset the base twice. Anyone got any solutions?
This is a known problem from November 2018. customer service sucks. returning unit asap. and deleting accounts.
I agree a 100%. Arlo is going to loose a lot of business if they don’t do something real soon.
I’m plugged in, the app recognizes my unit. When naming the base it cannot find it. Any ideas.?
I am having the exact same issue. Please someone help us!
If this is using a VMB3500 base, swap at the store and see if the new one works. Arlo is having some issues claiming a new VMB3500 base. You might want to consider a Pro system instead. Otherwise, open a case with support:
Also receiving the Aria Account Creation Failed message. Is there a solution to this problem? I've tried from my phone, which just says Arlo not available and logs out the app, and from the browser which gives this message.
Is there any other solution for this? I'm having the same problem of trying to set up my arlo cameras and base station for the first time. After I name the base station and click continue, I get a message saying that aria account creation failed. When I try on my phone I get the message no arlo device found. It finds the base station on the screen to select a base station, and it has the correct serial number. Model number is VMB3500 with a set of 3 cameras. First two lights are green and the third light is yellow. I've tried resetting the base station, uninstalling the app, and rebooted the router and modem and still got same results.
Right now you have two options:
1) Swap the system at the store
2) Open a case with support:
The VMB3500 base has a known issue and will not connect. Tech support is supposed to be working on it but has not fixed it yet. You might try opening up a case with them and see what they say now. Good luck.
It's currently a problem with the new round VMB3500 bases for some reason. You can try swapping at the store to see if the new one works. The Pro systems use a different base (VMB4000) and don't have this issue.
You did see the one year warranty, right? Use it:
Don't take no for an answer.
Arlo’s customer service is the worst. Not sure they are even really trying to find a fix for the 3500. If so, they would post a message to the community and provide an update. My brand new unit hasn’t worked since day one. I’m about to put it all back in the box and return it to Walmart. Will pick out a different brand. Does anyone have a suggestion? Bought an ARLO because of a friend recommendation. They must not have had to ever contact support. Horrible!
I agree with you just rung their customer service number Philippines nightmare - non-existant service. They have the option to connect you to the Philippines or India they don't have anything in Europe.
It's an issue only with the new VMB35600 bases. The fastest thing to try is to swap the system at the store. I don't know if this affects all of these bases or just some so the swap may help.
The Pro series uses a different base and doesn't have the issue.
1/28/19- Still an issue- VMS3030
Same model same issue. 1/28/19
@G808 wrote:
I am trying to setup my base station. I plugged it in and get two green lights. One amber for the sync. I went in my router to disable the firewall for the base station just to make sure that is not the problem. I have reset it several times.
On the iPad using the app I try to setup a Base or wireless camera. It locates the base station with the serial number. I name it and then hit next then it says no arlo devices found. Then I go through the setup again. It always finds the base station and gives me the serial number but after naming can’t find it. I have tried numerous resets of the base station, router, and iPad. Nothing changes.
On my Android phone app after I name the base station it logs me out of the app and has a banner on the top. It says we’re sorry arlo is currently unavailable. Please try again later.
Online it finds it and after I put in a name it says Aria Account creation failed.
After all of these I have done restarts on the base station disconnecting and reconnection cables, held the reset button on the base station until the lights turn Amber, reset my router, reset my devices connection to it, and nothing works.
