  • 1 Reply
  • 1323 Views
Truth2121
Can you get more than one base station to help with connectivity?
Dannybear
I don’t believe that there is any limitations to the number of base stations on your account.
Arlo recommends the use of multiple base units to overcome connectivity issues because of signal level issues.
Some considerations,
  • Ethernet cable to each base is required from the network router.
  • Backup storage devices required for each base if implemented.
  • Modes and rules need to be configured individually on each base, only armed/disarmed  modes are commonly controlled in the app.
