I have the original base station and three cameras. Everything worked fine for three years and now the base station keeps going offline. I reset and reinstall all the cameras and it will work for a day or so then go offline. Same modem, same settings same Wi-Fi service same everything. I reset everything then a day later base goes offline. Do they go bad? Yes I changed out cable too. I am at wits end as this is used to monitor vacation home.
thanks
It's possible that the base is going (or has gone) bad. Replacing it would be the solution but be sure to have a return privilege. I'd suggest a newer base, actually a hub, such as the VMB4540 which would allow you to also locally record videos as well as set you up for the current crop of cameras if needed.
