Hi All
So i purchased an Arlo 2 Pro and tried finding the base station on my Iphone and Laptop, all 3 lights are green and when i search for the base station, nothing is found after a 2 minute search on the APP and laptop.
Ive tried factory reseting the Base Station, called ARlo and had ports 80, 123 etc open... still no success... Anyone else had this issue?
Did you reset by pressing the reset button until the LEDs flash amber?
Did you ever figure out how to get your base station connected? I am having the exact same problem. All lights are green, I have factory reset, disconnected and reconnected several times. Wondering if you had any luck? Thanks.
If it's new, swap at the store.
Use the Contact Support link at the bottom here.
I cannot get my base station to connect it was fine last week is anybody else having this problem??
Thanks for the info, maybe several more resets before I find a new brand.
