Auto Deletion
How can I configure Auto Deletion? If the system knows you are at 80% full, someone can surely write code to auto delete the oldest files.
Go to SETTINGS/ SYSTEM SETTINGS / PREFERENCES
There is a click on/off option to delete old files and manage you storage automaticly
Under Settings / System Settings / Preferences you are prompted with three choices. None of which will auto purge your files.
The options are: Low Bat Notification, Storage Full Notification, and Push Notfication.
Storage Full Notification will only advise when you are 80% full. It will not auto delete, which is what i am in search for.
Arlo is great and I am suprised that such simple code has not yet been rolled in to production. Someone coded it to advise at 80%, why not take the extra step to parse.
vorsicle wrote:Under Settings / System Settings / Preferences you are prompted with three choices. None of which will auto purge your files.
Try on the PC via browser... here's what shows;
Try the first option... it AUTO deletes files after 7 days, they go in you recycle bin for a min of 7 days more ( if not longer due to slow housing keeping )
Those options are not avail to me.
I have used IE, Chrome from a PC and the app via my Smartphone.
Which subscription do you subcribe to? Maybe that's the difference. I have the Basic - Plan.
vorsicle wrote:Which subscription do you subcribe to? Maybe that's the difference. I have the Basic - Plan.
Ok... that answers it.. I have the Premier plan ( 30 days storage )
On the basic, the storage plan is already set for 7 days so it would be a mute point.
I believe the option to auto purge or delete would benefit all plans.
I have to manually delete. It would be nice if it would just delete the oldest day thus preventing me from having to log in to do it.
vorsicle wrote:I believe the option to auto purge or delete would benefit all plans.
So , if I may ask, you filling the 1GB in 7 days??
I don't think the auto delete really matters in a 7 days storage. I tried once to fill the 1GB running 5 cameras and it's pretty hard to do without killing batteries.
Remember, a ten sec clip is < 1 meg, so your talking about 1000 - 10 second videos.
So I don't think you would have to manually delete as the 7 day time will auto purge as the week goes on without filling your storage.
BTW, recycle bin doesn't count as part of the storage.
