I have had the Arlo security system for a few weeks and there is no Audio. How do I get the Audio/Sound?
The base isn't ahard drive but yes, that's what the cameras connect to. An easy way to tell which system you have (the box says audio so it must be the Pro) is the battery for the camera. The Pro uses a single "block" while the original wireless cameras use 4 separate batteries.
If you're not getting audio, use your app or web login to go to Settings, My Devices. Click on your cameras and check the settings in Audio Settings. Verify that the settings aren't disabled. If you make changes, test and see if all is ok. If changes don't seem to be necessary, it might be worthwhile to toggle them off and then back on and the power cycle the base using the power switch. Test again.
Also, make sure your sound isn't muted on your device (phone or computer) and that the volume is turned up. If using the app, sometimes reinstalling the app can clear up weirdnesses.
Let us know what steps you've tried, what you see and hear and how things work out. If you need realtime help, try calling support at the appropriate phone number listed in https://www.arlo.com/en-us/support/contact.aspx
