  • 5 Replies
  • 1679 Views
ronlittle
My Arlo wire-free cameras will not go to live video.  They do record movement.  Trying live video I get message to update to latest Adobe Flash.  I have done this several times and I now have version 32.0.0.238.  This appears to have happened when the Netgear split took place.  (I also had to re-install my system during the split)
More than likely it is the browser that's causing the issue...
many of the newer updates auto turn off flash....try and go to settings of the browser and turn on....
Like on FireFox, I had to click on the Lego type icon to left of address line....it allows flash to be used for the site
5 REPLIES 5
What browser do you use?
ronlittle
64bit Firefox v-69.0
And you don't see the "lego brick" after you click on "Live"?
ronlittle
Yes, that fixed it.  Thanks very much
