Arlo wireless cameras suitable for construction sites with no wifi and no power?
Hi,
Wondering if someone can answer my question regarding using the Arlo wirefree cameras on a construction site that is yet to have internet or power?
We've set up the baseunit in our offices as well as the cameras and everything is working well, but will we be able to place the cameras on site, and the keep the base unit connected to our internet and power in our offices?
Or does the base unit need to be within a certain vicinity of the cameras?
Thanks in advance for your help.
The Arlo base units require both ethernet connection ( internet ) and power.... tho the cameras are on batteries/wireless.
The max range is like normal wifi ( clear line of site ) about 300ft, but in real world it depends on what the signal goes thru.
Maybe 75+ ft through home
The GO cameras are celluar base, battery powered cameras and these may suit the location site better... look at them under Products
