HW Version - H7
Firmware - 1.2.10342
The range contiunes to get shorter and shorter, only about 3 feet now. Reset cameras, new batteries - no difference. When doing the motion test they work great and show a good distance, but once the test funciton is no longer on, the range is lost. Currenty have tryed on 50%, 75% and 100% sensitivity with the results being the same for all levels.
Thanks,
Open a case with support using the Contact Support link at the bottom.
cumekyad1,
Consider (temporarily) testing the camera in a different location to further isolate the issue. Do you see the same results?
tryed that and in multiple light settings - IR and in daylight. Same results. It's just like the sensors go bad after a year or two.
Do you mean move the base station farther than the wifi router?
While some users have reported that moving the base further from the base has helped resolve issues and is a worthwhile adventure for testing (use a long Ethernet cable or a WiFi extender with an Ethernet port), what I meant is that various wireless devices also use the 2.4GHz band and can interfere with the WiFi signal between the base and cameras. These devices can be other WiFi routers, cordless phones, microwave ovens, etc., etc. Do you have any wireless devices near your base?
But prior to this move, the router was in a room directly above the netgear base station. The distance is about 18 ft with 1 flooring in between.
I think the base station was designed to be connected directly to the main router. Which is cumbersome.
I'll try and move the router further see if it will work, or switch off the 2.4 ghz band and see if the cameras would respond faster.
Unfortunately i need a second router in my home to get a wifi signal throughout the house.
*update about having the 2nd router location. It seems that's not the cause because i disconnected and powered off the router, and yet the problem persists.
Could it be the channels?
Timz717 wrote:
Orbi?
Possible but, since it's happening to all cameras and getting worse, I'd have to surmise the base radio is having an issue. Only an open case with support will get this fixed.
I changed the router channel, reset all the cameras (including the rules), moved the location of the base router a few feet away. Then started working again..
Thank you for your help
