So I have a doorbell with the wires and the battery. But I don't have any single clue how to put it into wire mode. And don't get me started with synchronizing either. Took me 1:30 hours. I wish I was joking. I seriously despise it!
Anyway, got a handy guy to come over and put it on the wire. But how does this work? I can still see the battery function and the battery is at 99%. How does this work? Is it now running on wire or still on battery? Would appreciate it if Arlo made some good guidebooks with the model you have
Best answers
@Gur wrote:
And do you know when it will charge? Right now, the battery is at 93%
It depends on the model. The new ones ("Gen 2") tend not to charge for quite a while (that is a strategy to maximize the battery life). They are supposed to start charging when the battery drops to 65% and then charge until it reaches 80%.
Some users have posted different outcomes, but that might not have been with the current firmware.
It runs on the battery, but trickle-charges from the low-voltage AC supplied in the wires as needed.
