Arlo wire free, I have 2, went offline and now won't sync after last update.
Arlo wire free cams went offline and now won't sync after last update.
You will probably need to do a factory reset by using the pinhole in the back of the base. Follow the instructions in this article:
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
If the base is added smoothly, remember to only press the sync button briefly on the base and one at a time resync each camera by briefly pressing the sync button on the camera.
Brian
