  • 1 Reply
  • 4513 Views
Jaymaher
Arlo base station will not connect to sync to more than 5 cameras even though I have a 10:camera account
Are you saying you have a Premier subscription? Regardless, the base can support up to 15 cameras. If you can't get more then 5 to sync, I'd suggest removing all devices in Settings, My Devices and start fresh, using the Add Device button in the Devices tab to add the base. Sync the cameras normally, pressing the base sync button briefly (don't hold it). Any luck?
