Arlo vs Arlo Pro - Summary of Features Differences
  • 4 Replies
  • 144583 Views
  • 2 Likes
  • 5 In Conversation
Clark711
I am looking to buy an Arlo system, but I'm very confused about all the models, Pro, non-Pro.
Costco has a two-camera Arlo system at a good price.   Then I come on-line to check out the details, and now am confused.
Is there a summary listing of features of Arlo vs Arlo Pro ?    Where ?
I'm looking for a basic home system, probably 3 cameras, motion detection, siren is important.
On this website, the list for Arlo does not show siren but does for Pro.   Does non-Pro not have a siren ?    Other feature differences ?
Thanks,
Clark711
Clark711,
For a side-by-side comparison, take a look here and click the "compare" link: Arlo Products & Accessories
manfredz
Hero
Hero
As you observed, the Pro has a siren built into the base station, the Arlo basic doesn't
The Pro comes with a rechargeable battery but the basic doesn't but can use rechargeable RCR123A batteries (from Tenergy are authorized) but these rechargeables are often hard to buy outside of Canada and the USA.
Although both have USB ports they are not useable on the basic, but can be used for local storage on the PRO
The PRO cam has 2-way sound; the basic doesn't
I believe the PRO also has a better cam but not sure there.
Arlo camera was the original , Arlo Pro is sort of second gen.
Arlo uses 4-123type batteries/or rechargeables approved by Netgear
Pro use a single battery pack
Arlo used a PIR devcie to detect motion
Pro uses a dual PIR device to detect motion ( does it a bit better and faster )
Pro has audio, Arlo does not
The siren and local usb drive backup are on the PRO BASE only so the regular Arlo base does not have it
Both  cameras came be used on either base ( fully compatable )
Clark711,
georgebalanchin
In the battle of Arlo vs Arlo Pro, I'd say that the Pro version is way better. To make at as simple as possible, the Arlo Pro model allows the owner to gain full control over the indoor and outdoor activity. It's flexible, more reliable and secure.
So don't spare a few bucks since the Pro version can offer a lot more comfort and features.
