  • 1 Reply
  • 3131 Views
sauncho
I am looking into buying a Netgear C3000 cable modem with integrated wireless router. Am I correct to assume that the Arlo router will work when plugged into one of the 2 ethernet ports on the C3000 ?
It should work fins. As long as the ports are for the LAN, there should be no problem.
