Arlo standard, text message content
I have both email and txt message notifications enabled in my motion alert modes. That process works fine. However the content of the text message is my concern as it is a mixture of a proper subject line and html coding that does not even identify which camera is alarming. Is anyone else is having this problem?
1 of 10
FRM:alerts@arlo.com
SUBJ:Arlo Has Just Detected Motion
MSG: This Just InaΔ¿ body{
(Con't 2 of 10
background:#EEEEEE; padding:45px 5%; margin:0; position:relative;
(Con't) 3 of 10
display:block; font-family:Arial, Tahoma, sans-serif; cursor:default;
(Con't) 4 of 10
line-height:normal; } a,img{ outline:none; border:none;
(Con' 5 of 10
} .fixed-table-layout{ display:table; table-layout:fixed; }
Mo
looks like the servcie provider isn't stripping out all the formating when converting the email to an SMS...
some do a good jod, others not so much
Have you changed phone or service lately ?
It depends on the carrier... verizon isn't as bad when converting... not much you can do unless you go thru a third party service
