Arlo siren on original wire free system
  • 2 Replies
  • 3118 Views
KLP
is it possible to hook up a sirene to the std. system?
To use a camera to trigger the siren you would need to have that camera synced to the Pro base. You can't cross bases like that.
brh
@KLP
Not to the best of my knowledge. But, you could purchase a Pro base and even if you had no cameras attached to it, you could use either manually or, I believe, set up any of your cameras to trigger it. One other way is to connect your cameras to a Smartthing hub which is what I am doing. With Smartthings, any device that is connected to the hub can set off the siren, (cameras, open/closed sensors, motion sensors, etc.).
Brian
