is it possible to hook up a sirene to the std. system?
To use a camera to trigger the siren you would need to have that camera synced to the Pro base. You can't cross bases like that.
Not to the best of my knowledge. But, you could purchase a Pro base and even if you had no cameras attached to it, you could use either manually or, I believe, set up any of your cameras to trigger it. One other way is to connect your cameras to a Smartthing hub which is what I am doing. With Smartthings, any device that is connected to the hub can set off the siren, (cameras, open/closed sensors, motion sensors, etc.).
Brian
