Hi I recently purchased an Arlo system , I live in the country and the internet connection is not the strongest ... the cameras wont sync to the base they are flashing orange wich according to the guide means there is no internet access , I am debating returning them ... Has any body come across the same problem ?
Netgear does spec at least 1 MB upload speed...
If your upload speed reaches at least 1 Mbps, try the steps on the link below to sync your camera.
