Arlo recording, can i increase that time interval?
  • 5 Replies
  • 4237 Views
  • 5 In Conversation
frrailroad
each motion detection records 10 seconds, can i increase that time interval?
The time can be increased up to 2 mins...
You have to go into Modes, then pick  edit ,then pick camera and edit again, then edit the record  by clicking edit pencil and adjust time.
I do recommend not using the default modes but "copy" them into a new custom mode and do editing there.
5 REPLIES 5
winwang
Thank you for your input. I followed your instruction, but the new length was not taken. why? I don't see "save" button.
winwang
I got it. the "save" button is when back to "Edit Rule". thanks so much
NYCTheo
I followed all your instructions but when i go to mode, then armed, then edit, there is nothing about extending time....all i see is sensitivity detection...
Next section down - "Then Do The Following". Edit the Recording Video section.  If that's missing, you either need to make your own mode with appropriate rules for your cameras (this is the recommended method) or reset your base, remove all devices in Settings, My Devices and start fresh using the Add Device button on the Devices tab.  This will rebuild the default modes.
