Arlo "update your cameras firmware now"
  • 5 Replies
  • 6641 Views
Mangawhai
When I go to look on the camera it tells me to "update your cameras firmware now" I tap the update button and it says that the update is in progress and don't turn off your camera. If only lasts about 4 seconds and then it tells me to start it again.
Streak2
Master Master
Try and reinstall the app on your phone.
Use the web interface to see if there are in fact any updates
arlo.netgear.com
5 REPLIES 5
steve_t
Master Master
You camera may be too far away from the base station or your internet connection might be too slow
Mangawhai
Thanks for that. I thought that might be the problem so I placed my phone next to the base and still nothing. Am beginning to think it may be a fault in my phone as my wife's one is working fine. Thanks.
Streak2
Master Master
arlo.netgear.com
Mangawhai
Thanks mate...that did it...back up and running...if I knew where you were there'd be a beer coming your way...appreciations...
BTW, placing your PHONE near the base isn't needed. The initial suggestion was to place the CAMERA near the base.
