iPad, my preview screen changed. I can only see small views (bigger than thumbnails). I see to see larger views. I cannot find any adjustment
5 REPLIES 5
Thanks for clarifying. Unfortunately there is no adjustment to make the thumbnails bigger on the Arlo app. However, feel free to post your suggestion on our Idea Exchange Board to receive kudos for the idea!
Can’t be right. I have two iPads, both have same app. The other one shows the larger view, this one doesnt
What Arlo app versions are you running on both iPads? And what iPad models are you using?
