  • 5 Replies
  • 2580 Views
gec8817
iPad, my preview screen changed.  I can only see small views (bigger than thumbnails).   I see to see larger views.   I cannot find any adjustment
5 REPLIES 5
JessicaP
Hi @gec8817,
Just to make sure, are you wanting the thumbnails to be bigger on your iPad?
gec8817
@JessicaP wrote:
Hi @gec8817,
Yes.  Bigger.  Tks
JessicaP
Thanks for clarifying. Unfortunately there is no adjustment to make the thumbnails bigger on the Arlo app. However, feel free to post your suggestion on our Idea Exchange Board to receive kudos for the idea!
gec8817
Can’t be right.  I have two iPads, both have same app. The other one shows the larger view, this one doesnt
JessicaP
What Arlo app versions are you running on both iPads? And what iPad models are you using?
