The original batteries lasted 5 months a set of replacement batteries lasted 4 weeks. I didnt change any settings. I only changed the batteries, what is up with that?
Should have been the same... I generally get almost 4 months on best video.
So, maybe they were bad, maybe the weren't seated properly in the unit ( test with voltmeter if you have one ) , sometimes the contacts dont touch properly...
were they the same size, type as OEM ?
