Arlo not recording
I was away on vacation last week and Arlo stopped recording. People were coming and going on the property, feeding cats, mowing lawn and nothing triggered motion. I am still unable to get Arlo to detect motion. The cameras are on and I can see and record from my phone.
First thing to do is go to the live view screen and verify the "motion detect" icon is Black ( means on )
If they are black then try a reboot of the base...
There is no little man! I turned off base unit and removed all cameras. Turned on base unit and confirmed all updates have occurred. I added one camera and have done everything to try to get it to detect motion and nothing happens. I can view and record from my phone.
Are the motion icons grayed out or missing completely ?
No motion icons!!!
I would verify on another browser ( https://arlo.netgear.com ) or use another devcie that the icons are not there.
If using a phone I would un-install the app and reinstall
The motion icons are either a running man (web) or a small ball and 3 horizontal lines (app).
Strange... I could see that the cameras were on, see the view and record. However, the base station said it was disarmed. So I changed the setting and everything works. However, when the base station is disarmed you should not be able to see anything. It was showing it as armed when I checked this past week. Confusing.
