  • 16 Replies
  • 6932 Views
  • 5 In Conversation
Murtaugh
Help!!!!
My Arlo camera were up and running fine for about 3 months and now won’t work.
They won’t auto record anything after motion is detected.
They show good batteries
I can see live video
They do detect motion and give a “1” to the apple icon on my phone and beep the phone when motion is detected.
They will record video on demand.
They won’t auto record anything after motion is detected, rendering the system worthless for security.
I’ve tried:
Rebooting everything, reinstalling Arlo softwarter on phone
Checking for Arlo firmware updates
Rebooting modem-wifi
Resyncing cameras.
Help!!!!!!!!!!!
16 REPLIES 16
When the cameras are ARMED. in the LIVE VIEW screen, the "running man" MUST BE BLACK.... if he is gray, the camera will not record from motion detect.
Either the modes/rules are incorrect or the base will need a factory reset ( hold in reset for 10 sec till the leds flash amber ).
I'm thinking since all else is working the Mode or similar is messed up.
If all looks good, then reset the base...resync may be required as if new
Murtaugh,
This could be a symptom of old firmware. What firmware is your Arlo base station and cameras running?
You can check the firmware by logging in to your Arlo account and navigating to Settings > My Devices > select base station/cameras > Device info.
Melpalmer22
Frustrated to the Max!! Bought two Arlo cameras today and cannot for the life of me get them to record when motion is detected.
I can record mannually, I can watch live, I get notified when there is motion, but cannot get it to automatically record. Very frustrating.
What have you tried?  Are the running men for each camera in the Devices tab black or gray?  Gray means disarmed.  Check the Mode tab, click on your base and see what mode is selected - by default it should be Armed.  Also, check your firmware versions in Settings, My Devices for the base and each camera.  Old firmware may cause this.  It should automatically update overnight so if there's no pending updates, check to see if motion is now being detected and recorded.
Melpalmer22
Ok so. So last night the running men were weird. When I look at the screen showing the cameras the running man was black, when I walked in front of them and set the motion off the running man would go orange for a sec or two and then would Grey out. I tried resetting cameras and base and re syncing them.
I checked the firmware but I don't know what's the most updated, but if also doesn't tell me any updates are needed.
So I wake up this morning and the camera is now recording motion and all I did was give up an go to sleep haha So I have absolutely no idea what's going on.
Murtaugh
So someone mentioned that there is a tab on my base that should show "armed" by default and the running men in the devices tab should be black.  Neither is true but I don't see any6hwere how to arm the base or change the device setting for the running man.  Hey, This COULD be my issue.  But does anyone know how to fix it.  The software and firmware show no updates avaiable and my internet connection is good enough for Netflix.
Melpalmer22
Went I went to sleep last night there was no 'Armed' mode on my phone app. When I woke up, there is now and 'Armed' mode which it's now the default mode and it works perfectly!
It's the Mode tab. Click on your base and check the selected mode (default is Armed).
Melpalmer22
I don't know why things can't be easy and just work.
Jguerdat - I know have one camera working perfectly and one camera that won't record (all you can do is watch live) any way I can fix this camera. Also when I go into mode for this camera is is set on 10seconds and will not allow me to slide the circle button to extend the record time.
Try power cycling the base. Also, remove the camera from Settings, My Devices and resync it.
Melpalmer22
Ok so I worked out that you have to have either Email or push notification alert on. They were both off for the non working camera, but when I put email notifications on it started recording again.
Notifications are not required to record.  Typically, I have all of mine off.  It sounds like something happened, perhaps to the rule or mode, that making a change caused to be refreshed.  Try removing the notifications and see if it still works.
Murtaugh
The notifixcations or push did not resolved the problem.
Murtaugh
Has anyone found a solution for this.  I guess I just need to toss the whole syste???? No recording adter motion detection works after the software update..
Murtaugh
How do you change the mode tab on the base?  I don't see any tab.  I think the LED by the house is what you mean as it is not green or lit.
The Mode tab is in the app or web I interface, not physically on the base.
