I just wanted to create a thread, for anyone searching for reviews or help on Arlo, to AVOID these useless cameras, as well as vent some frustration. The product does not work well at all, and certainly not as intended, especially for the price you. If you want reasonable results you need to pay for a monthly subscription, and even then it is very hit and miss with how they function. At this point, after not only hours but days of troubleshooting, and living with the below mediocre performance that Arlo is, all I can conclude is to avoid this turd of a product and buy a real solution. Save your money and buy a Ring or a Nest, anything but Arlo!
Can tell you from experience ring has alot more problems and less features. And also require a subscription.
I can't see anything having more problems than these. They are unusable. The base station drops the internet connection constantly. The video lag is no less than 15-120 seconds. Quality is well below par. (It may look bright and colorful, but there is zero detail). I concur, DO NOT BUY! Go get yourselves a hardwired Hikvision or Axis system. It's a world of difference and less hassle after initial installation, and it will do what it's supposed to do.
So did you buy it the first place? Did you not do research before you bought it?
Not nearly as much research as I should have, which I why I added this thread with the "Before You Buy" label on the Arlo forums. Hopefully it will save future Googler's time, money and headaches. Don't repeat this mistake!
I have have pro3 so it does have alot more features that i was talking about I dont have older arlo models in this forum. . Even Rings new stick up battery cams has max 30 second motion recording and hardwired have 60 sec. Then its started again about 10 - 20 seconds later.
The free service is motion alert and live streaming on ring. you need at least the basic subscription for cloud storage at least now. Not sure if other Ring models had local storage. Defeat's the purpose to view past events without storage on free plan. If it works for you then ok
what good are features if they don't work or are not reliable! literally just now my neighbors dog walked in to my yard, took a dump right in plain view of the arlo camera and it did not detect or record anything! pretty good analogy for this system to be honest. i will gladly pay a $10 /month fee for system that WORKS, not pay for one that does not. these things are going in the trash and for anyone reading this I suggest you avoid these as well. Even the subject of this thread was changed by a mod! it was originally titled Avoid Arlo Do Not Buy and was change to Vent Frustrations. Product is terrible, support is terrible a damn waste of money. if you want further proof go cruise the threads, it's all the same. Base station not connecting, cameras not recording, the list goes on. AVOID!
