Arlo in two homes
I saw a previous answer that you can have arlo systems in separate homes and under the same account. The question I have is if one is at my beach home and the new one will be at my perminent home, do I title each as such and I can toggle back and forth on my phone? Or do all cameras show up on the same account and I will have to determine the new ones by appearance? Thanks
There is no limit on number of bases , nor locations, on any account...the limit is the number of cameras for your service level.
So, if your on Basic ( free ) level, you can have a max of 5 cameras.... you can install 2 cams and a base in one home and 3 cams and a base in another.... they will all appear on the same account together.
The major difference is that under MODE, you will have two bases listed and each has to be armed /unarmed separately.
You can name the cameras as needed to know what your looking at.
