  • 1 Reply
  • 3056 Views
MurrayK
Starting to get a little bit annoyed that a $1k system has this many problems. Started working fine, then the arlo will have a random fit where I cant connect, when i go to kode it says stuck on getting status, cameras say its offline and not connected to the internet, it will send me a notification saying it captured motion, however the videos only get saved some times, and for example i logged in at like 9 today and it had 2 videos saved from the morning, log in at 10 and they are gone.
Wont show me firmware either
Arlo https://imgur.com/gallery/MZJEJ
MurrayK,
Consider rebooting your base station (using the on-off button), allow the base to come back online with a solid green power and internet LED.
Are you still seeing the same behavior?
