Arlo free base station all lights continuesly blinking at once
To factory reset the base, press the reset button for several seconds until the LEDs flash amber. Having all the LEDs flashing would seem to indicate a real problem that a reset may not resolve.
Gotta give us details. WHICH light is amber? What are the others doing? Details!
Try a factory reset using the reset button until the LEDs flash amber. Did that do anything useful? It does sound like a bad base or power supply. Is this a new purchase? You may be able to swap the system for another. Alternatively, a trouble ticket would be useful to get you an RMA for it.
Vincent88,
Are you by chance using a different AC adapter than the original adapter supplied with the Arlo base station? A screenshot of the specs for the original can be seen here: https://community.netgear.com/t5/Arlo-Wire-Free-camera/Power-Supply-Adapter-Suddenly-Stopped-Working...
Vincent88 wrote:
I'm not sure if this is the original the brand name is Graco class 2 transformer input 120vac output 9vdc
The power transformer for the Arlo BASE is 12v dc at 1.5a output to a coaxial plug, center positive.
