To factory reset the base, press the reset button for several seconds until the LEDs flash amber. Having all the LEDs flashing would seem to indicate a real problem that a reset may not resolve.
Gotta give us details. WHICH light is amber? What are the others doing? Details!
Try a factory reset using the reset button until the LEDs flash amber. Did that do anything useful? It does sound like a bad base or power supply. Is this a new purchase? You may be able to swap the system for another. Alternatively, a trouble ticket would be useful to get you an RMA for it.
Vincent88,
Are you by chance using a different AC adapter than the original adapter supplied with the Arlo base station? A screenshot of the specs for the original can be seen here: https://community.netgear.com/t5/Arlo-Wire-Free-camera/Power-Supply-Adapter-Suddenly-Stopped-Working...
Vincent88 wrote:
I'm not sure if this is the original the brand name is Graco class 2 transformer input 120vac output 9vdc
The power transformer for the Arlo BASE is 12v dc at 1.5a output to a coaxial plug, center positive.
