  • 21941 Views
wensi
Hi,
I am wondering when the cold temperature which cause the low battery would be solved, is there any ETA? This problem exist for a long time, and still not solved yet.
Thank you。
DeannS
Good morning wensi,
If the camera's are placed outside in extremely cold weather, the batteries may give a false reading. Please refer to this article My Arlo cameras are reporting low battery In cold weather
The article below refers to rechargeable batteries that may increase your battery life with the Arlo system:
Rechargable battery usage vs time by type post spec info only
This will usually occur in weather below 14 degrees.
Operating temperature
14° to 122° F (-10° C to 50° C)
What is the current temperature where you are located?
I hope the information above has helped.
I look forward to your response.
Thanks,
DeannS
Arlo Team
wensi
Hi,
Thank you for reply, would you pleae send me the link for the best rechargable battery for Arlo camera, i need to purchase some.
Best regards,
Wensi
Based on the 3 brands I've been testing, the TangsFire 1000 mAh batteries are doing the best by far.
http://www.amazon.com/s/ref=nb_sb_ss_i_6_10?url=search-alias%3Daps&field-keywords=tangsfire+16340&sp...
