Arlo cameras only recording for 1-5 seconds
My cameras are set to record in various times based on locations, with most set to 45 seconds. All of the recordings are ending recording typically after 1 second, sometimes maybe 5 seconds. I reset the base station with no success. Any suggestions on what to do?
I suspect your power cycled/restarted your base, not reset it. If you want to do that, remove all devices from Settings, My Devices. Use the Add Device button to add the base and sync the cameras. Verify that your firmware versions are up to date compared to what's posted in the Release Notes section here.
