Arlo cameras going offline
Hi @Jmmurrell
I'm actually so pissed off at this thing that I went back to the Amazon site to write a review only to see that I already wrote one with 4 stars. I want to give ZERO stars. This service *. Do yourself a favor and buy something other than Arlo. Yes, I understand that the batteries do not last long. I knew that going into the purchase. The further away the camera, the worse the battery consumption. The more false triggers, the more battery consumption. The more recordings, the more battery consumption. I get and accept all that. But you know what I can't forgive? I can't forgive when Arlo/Netgear seemingly makes an update which puts the main base unit offline. When it goes offline, all the cameras start looking for the signal which drains them at about 10% an hour. So in 10 hours, a fully charged battery is completely dead. The batteries are roughly $2 each. Each camera has 4 batteries. I have 5 cameras. It wastes $40 each time they go offline!!! THERE IS NO EXCUSE FOR THIS. Looking through the forums, this same issue applies to the Arlo Pro and Arlo Pro2. Each time they go offline, the Arlo forums get flooded with people complaining that their devices are all suddenly dead even with fresh batteries.
And NO, I didn't contact support for this. With 5 years of running this stupid thing, I already know what they are going to say. "Did you reset the device? Did you check the batteries? Are you sure they're new? Delete the devices and resync everything [which, btw, erases all of your rules and settings... thank you!]". Bottom line... this service is a * It didn't start this way... but it surely ended this way.
Can you please clarify - it sounds like you are suggesting that when Arlo does an update and the base goes offline, the camera(s) consume their battery life and U are required to but new batteries?
