I moved to a new house and am trying to set up my cameras again. Do I need to delete each camera from my base station and set them up again or can I just plug in the base station and try to sync them? Do I need to enter new Wi-Fi information anywhere?
You should be able to just plug and play. The base station connects via an ethernet cable so even with a different wifi router, it should work fine (as long as the ports are open) because it doesn't connect to the internet via wifi
