Arlo Wireless Motion DetectionRange and %age Sensetivity
  • 1 Reply
  • 2304 Views
Moose2
Hi, Cam is inside covering outside, whats the Maxium Range for the MD to Work?..also the % Scale which way does it work?
Higher % less chance of it going off with Animals etc?
Any possible intruders or Callers is my MD aim
steve_t
Master Master
Range is dependent on the size of the heat signature
100 is full sensitivity and will trigger with trees waving in the breeze if they're close enough and animals do trigger it off. You'll have to spend a while finding out what the best sensitivity setting for your area is. I suggest you start at 100 and drop it down as required
