Arlo camera viewing angle
  • 1 Reply
  • 25049 Views
ArloNewbie
I need to determine how manay cameras I will need to cover my entire house. What is the Arlo camera's viewing Angle? Will one camera cover an average sized room?
ChristineT
Hello ArloNewbie,
The Arlo camera has an impressive 110 degrees viewing angle. I have found that mounting the camera high up in a corner allows me to view my entire living room. When mounting your camera you'll want to keep in mind the motion detection range is approximately 15 feet. So, depending on your needs and the size of the room you may consider two cameras on either side of the room.
For more information on camera installation and placement check out these videos: Arlo Installation and Using Motion Detection.
Thank you for your inquiry!
Christine - Arlo Team
____
Please click KUDOS or REPLY if you found this helpful.
