My Arlo is showing failure to connect. If I restart the drive do i have to reset all 4 cameras by removing batteries My internet works fine . the on screen display shows the 4 screens but there is no battery icon. when i hit play it just says failure to connect
Fixed it just turned hub off and then back on and all cameras reset thanks all
Are you trying to Live Stream from the app, and if so, which one? Or are you using a browser on your PC? If so which one? Is the system otherwise useable? The battery icon has been changed in the apps - it only shows up now if the battery falls below 15%.
Brian
Are you a basic free plan or a Smartplan subscriber on your system?
