Arlo camera showing "Failure to connect"
  • 2781 Views
LoriVal
My Arlo is showing failure to connect. If I restart the drive do i have to reset all 4 cameras by removing batteries My internet works fine . the on screen display shows the 4 screens but there is no battery icon. when i hit play it just says failure to connect
LoriVal
Fixed it just turned hub off and then back on and all cameras reset thanks all
brh
@LoriVal
Are you trying to Live Stream from the app, and if so, which one? Or are you using a browser on your PC? If so which one? Is the system otherwise useable? The battery icon has been changed in the apps - it only shows up now if the battery falls below 15%.
Brian
Runner56
Are you a basic free plan or a Smartplan subscriber on your system?
LoriVal
