I’ve had this Arlo add-on camera for the past two years. It has always performed very well, but the battery life is now awful. Same location, same distance from base unit, but very poor battery life. Used to get 3-4 months and now I get just 2 weeks. I’ve tried different brands of lithium batteries, but the results are the same. I’ll go broke at this rate! I appreciate any helpful tips to save the camera and my wallet. Thank you.
You could also try swapping cameras around to see if it's the camera or location.
My batteries are doing the same except I just had to replace batteries after 2 days. My cameras are in the same place they've been in for a year. I tried re syncing them but it didn't help. I removed the base then re added it but that didn't help. I can't afford this! It seems to have gotten worse after the 2.7.0 upgrade. Help!
I’ll try the reboot the next time I travel to its location. Thanks for the suggestion.
Clearly there is another issue at play. My other cameras operate perfectly on the same system.
