  • 14 Replies
  • 4513 Views
  • 2 Likes
  • 6 In Conversation
TheLookout
Hello,
I just set up the cameras last night, and the one for my front door disconnected. This morning I was checking them out and it said not connected. So I tried connecting it again and it didn't work. So I opened the battery cover and moved the batteries around and then it did connect. However, it quickly disconnected again. It was 8 degrees (Celsius) last night, and the other camera that was outside was fine. I am thinking either (1) the batteries it came with for that camera are defective or (2) the unit is defective. Because of the manufactures warranty, how would I use it for the one camera?
14 REPLIES 14
TheLookout
I just got the cameras yesterday BTW. Would bestbuy exchange one for me? The other ones seem fine. What do I do?
TheLookout
So I had an extra camera and swapped them. So the initial camera that was disconnecting is now working fine once I brought it inside, and the one I put inplace of the one that was disconnecting is working (for now). I'll update after another night (current time: 8:18:58 AM). Maybe that location isn't good? But I have another camera near it which is working fine, so I am confused.
I'd wager the camera is having issues maintaining connection with the base (BTW, this is the Q camea section which doesn't have batteries or a base station).  This struggle can be due to interference from other 2.4GHz wireless devices or the distance, including any attenuation from walls, ceilings, metal flashing, ductwork, etc.), between the camera and base.  A quick test would be to swap cameras around temporarily to see if the problem is due to the camera or the position.
P.S. - if it's due to a poor signal, the batteries will wear out quickly.
Edit:  You beat me to the swap. You'll probably need to reposition the problem location somewhat to fix the issue.
TheLookout
Yeah I will test it out. And I am sorry I put this in the wrong section. I thought the Q for Q cameras meant, question for Camera! Lol. I'll update the post after tonight.
TheLookout
Thanks a lot for your advice!
Retired_Member
Not applicable
Got the same problem. Bought an Arlo 4 HD Camera Pack from BestBuy canada yesterday (26-april-2016) Hardware=VMB3010r2, Software=1.7.3_5005. DSL router is Dlink DSL-2640B (4.01EU). Settings is on optimised. Push/Email notifiication with 80% motion detection sensitivity. One camera nearest to the house (front door) got disconnected overnight with same temperature as original poster around 10 degrees (Celsius). The other 3 ones which are also outside but further away from the house is still connected all batteries are still full. Tried to reboot the base station remotely this morning but that camera is still disconnected. At night this camera has front door light that illuminates the view. The other 3 ones are almost pitch black. My question is why after less than a day?
mcmu12
Luminary
Luminary
I've had mine 8 mos and it keeps going offline yesterday and today. All 3. If that is your issue, it's not you. Several others are having the same issue. I haven't done anything to correct but it fixes itself. Aggravating Arlo Netgear has a problem
Retired_Member
Not applicable
Thanks mcmu12 for your input. Its greatly appreciated.
mcmu12
Luminary
Luminary
Also I have mine all outside in TN. Only had to take them inside one night this winter. I think they say 12-15 degrees is the limit for the cameras.
JN_2016,
The location of this camera could be the issue. It may be struggling to maintain connection with the base station due to interference or range. To further isolate, you could try swapping the location of the affected camera with one of your cameras that is behaving normally to identify if the location is the cause of the issue.
FWIW, I've had mine in slightly sub-zero temps with no problems.
Adewale
Luminary
Luminary
3 of the 4 cameras have suddenly disconnected from the base station yesterday...they have been at their current location for months so i know the problem is not location as i have not moved them around....am i missing something...what could be responsible for this?
Adewale,
It could be that the batteries for these cameras are depleted. You might try a fresh set of batteries in the affected cameras and see if they come back online.
Adewale
Luminary
Luminary
I am very sure the batteries are not depleted.
I pulled the plug on the base station and plugged it back and the last time i checked (a few mins before this post), the base station restart seems to have cleared up the issue
