Arlo battery issues with 2.4.4.09.1044_18113 (giving up)
In the past month since this update was realsed 2.4.4.09.1044_18113 my batteries on my arlo cameras have died incredibly fast this is the second time repalcing the batteries in 2 weeks can someone please help or if there is a way to downgrade to older version.
First, you posted the app version, not firmware version which you seem to be suggesting is the problem.
Next, what have you tried? Have you power cycled the base and opened and closed battery doors? It's possible that removing the cameras from Settings, My Devices and resyncing them may help.
Then, what may have changed about your wireless environment? Especially near the base, has any equipment of any sort that uses the 2.4GHz frequency been moved or installed? Sometimes moving the base even a little can be useful.
Also, have you considered rechargeable batteries so your budget doesn't get eaten up?
