Arlo battery drain
AT&T did an update yesterday to my Galaxy S7 and now my Arlo batteries are draining. Can this be possible that the app somehow is messed up draining the batteries on both cameras?
Nope. You can try reinstalling the app but I wouldn't expect anything different. More to the point, try power cycling the base.
Just in case, tho don't think it will make a diff... but it's easy to do.
Open the app in your phone , do a forced stop and clear the cache ( not data ).
Power you phone off then back on ( reboot the phone. ) start app back up.
